gear ratio recommendations
M
mngoat
Running a pro with a 156 2.5 camo track....8 tooth avid drivers.....around 200hp....410lbs sled....purely a boondocking sled some tight tree riding but not a ton...my gearing options are 1.93,2.0,2.07,2.15,2.23,2.32,2.42,2.52.
I have traditionally always geared my sleds fairly low(probably lower than they need to be) but i also don't want to be spinning a ton of rpm's buzzing down the trail at 45.
Any suggestions are appreciated. Thanks.
8t driver is stock on the Pro.
With that much HP you aren't going to have an issue turning the track. I have always been a fan of the 2.05 ratio so I'd opt for 2.07 if it were me.
sled_guy
