Gear down clutching changes
ullose272
3,372
965
boise idaho
Just did a TKI with 28T 2.25 ratio, what do you guys recomend for clutching changes? Steeper helix?
Sent from my SM-G973U using Tapatalk
  • 2 Stars
Reactions: Over budget
die hard poo
1,177
796
Kenai, AK
I went quite a bit lower, 2.52 ratio and had to put a steeper initial angle helix to get the motor loaded, I am running a 60/42 right now. Overall its better than the stock helix. But with your 2.25 I don't think you will have to change anything.
damx
1,837
1,179
On my 19 850, I ran qd1, pro gears and now qd2. I have used the TRS kit the hole time. With the qd1 and pro gears I never changed a thing with clutching. With the qd2 I went from the 46 to the 42 start angle, the sled pulled better in that angle.
kylant
1,672
396
83
CA
i was curious about the same thing.
I have a 2020 850, started life as a 155.
It has TRS clutching.
max rpm was about 8300, maybe a rare 8350
now sled is a 165, with 6 tooth 3.5 drivers, and QD2.
same TRS clutching.
Now sled will hit 8450 easily and I have seen 8550 a time or two. seems a bit higher than it should be.
should anything be done?
damx
1,837
1,179
Kylant add some clutch weight, I also added a doo 165 track at the same time as the qd2, so my set up is a bit different.
Over budget
231
241
Centerville utah
same TRS clutching.
Add 2grams to your weights
