I'm riding at 3000-4000 ft elevation and I want to change gears from stock (20/42) to 19/43!
What should I expect RPM wise ? Drop or Rise ???
Thanks!
Thanks!
Thanks!
Thanks GMan!
The reason is, right now, I'm pulling barely 8000 rpm! I have the 163"
I'm having an argument with a friend and want to make sure before I actually do anything to the gearing! If I do it...
So a drop or a raise of RPM ???
Thx
Gearing down will drop your RPM's slightly, you may not notice it much on the flatlands but due to a little less resistance when pulling a hill your backshift may suffer a bit. You may need to run a bit lighter in the primary, or a couple degrees less angle in your secondary, or possibly slightly more spring in your secondary if you have issues. 8,000 to 8,050 is exactly where you want to be.
I hope you did not realize what gearing change he is making..... He is asking about gearing DOWN. If you lower the gearing ratio, the motor will have less load on it and would pull more rpm.
Eh a
You may have to do the opposite of what is quoted above, but most likely no changes will be needed. You only dropped your top end 1:1 shift out speed at 8250 rpm by 6 mph.
I will guarantee if you marked your clutches with a black marker you are not using the top half inch of your sheaves with stock gearing. Stepping the gearing down will help in most every condition to better utilize more of your larger clutch sheave diameters, reducing belt temps.
What way are you running the ethanol key? Running good fuel and the non ethanol key will help the motor pull harder as well.
I am not trying to argue against anyone here as I know that you guys know a bit more than me, but would elevation play into that much? I ride at 6,000+ a lot.
do you have the 20/42 gearing and a 1115 belt on it?while people are talking clutching, my sba with the 2in track is slipping th ebelt in the primary on bottom. got the stock 66's in there, sled pulls the rpms fine, i have messed with the deflection to see if that was my issue, it wasnt. i am thinking i need to buy some after market weights, staying very close to my weight now and just adding some to the heel to get it to grab the belt better. but i don't want to loose it further up. i can look what i am currently running for springs/helix tomorrow. i am only riding 1500-3500 sometimes few hundred higher but not alot. ehna sorry not trying to hyjack your topic here.
