I'm just curious on what other people have used for a boost gauge. I am planning on needing one for water temp, a/f ratio, and maybe egt. Some may say I will not need water temp but its a personal preference.
Air/fuel, boost, that`s it. Less gauges, more time to look where you going . if I should be serious, I do not think EGT meters is accurate on boost applications.. There is too much fresh air going into the exhaust..
I like having egts for the trail. I also check them while climbing, but not before I look at my af gauge. I wouldn't recommend the AEM af gauge. We have 3 broken ones in our group. The plastic housing is very weak. If you get one don't use the clamp that holds the gauge in place.
Good to know! I will try and rig something up to keep it in place, maybe a bead of silicone or something.
