I know that they show the measurements that way, but it isn't true if you lay them side by side and compare. I think Gates uses a defective tape measure. I ran into this problem even on the old M7, there belt was so short it wouldn't possibly work. They cross info they had on the old 0627010, and 0627020 was backwards also. I hope the new number is correct.
So, will the 37C4604 work on my 2014?
Yes. The 37g4604 is the same as the 37c4604, but the 37c4604 is the carbon fiber cord belt. Supposed to be stronger and more expensive. I run the G series and have great luck with them.So will the 37G4604 work as well? That's what the guy at Napa sold me when I told him I needed a belt for a 2013 m800.
Hope you guys out West will give it a rip and see if an affordable replacement has been found.
I would now buy this over the previous belt (4604 above) as that one is a bugger to get the deflection adjusted right with it being narrower.
