T
Twisted Tunnel
Trying to clear out the shop a little bit so I'm giving you guys a big long list to look through. I have a lot more parts, so feel free to ask if you don't see what you need.
05-09 IQ and Dragon chassis
Mechanical Reverse for 550 or 600 $300
PSI triple pipes and stingers for xlt 600 $150
Van Amburg gen 2 chassis and tunnel $500
CMX gen 2 chassis and tunnel $300
Polaris Indy Lite 340 motor and parts
Lots of gen 2 hoods, stock and aftermarket
425-652-9622
Located in Cle Elum, Wa
- Dragon, 900, and rmk gauges $150 each
- Straightline hood vent kit (new in package) $30
- Brake pod/switches $100
- 7" Fly Pivot Riser $80
- 2" riser $25
- Billet handle $30
- 07 Dragon 700 SLP Pipe and Can $300
- 07 Brake caliper $60
- 07 Dragon 700 Fuel Pump $100
- 06 900 Fuel Pump $100
- 07 Dragon Stator $125 and flywheel $100
- 09 Dragon 800 Pipe $150
- 08-09 SLP Can $150
- 06 rmk 900 chaincase $100
- 05 rmk 900 chaincase $100
- 1 walker evans front air shock $150
- Dragon seat $150
- 07 rmk 600 seat $125
- 05 rmk 900 Yellow inj Ecu $200
- 800 VES power Valve $50
- shock towers $20 each
- coil $30
- 03 800 cdi $100
- stock pipe $100
- Head $80
- oil pump $50
- Ryde Fx solo rear shock w/ rebound adj $200
- Complete chaincases with gears and chain $100
- Diamond S hood $150
- 800 bottom end in good condition $350
- gen 1 hood hinges $20 pair
- SLP aluminum boost bottle $25
- Powermadd Throttle Extension $25
- Fabcraft Mountain Strap $25
- Gen 2 complete radius rod set $80
- 01 Holz Trailing arms $200
- 01 PLP Trailing arms $125
- Fox shocks $150
- Holz coilover no rails or rear axle $300
- 159 Holz w/ fox zero pros $500
- 01 rmk 800 cdi $50
- 97 rmk 700 cdi $125
- 01 rmk 700 carb boots $80
- Vforce reeds $80
- Tuff Trix Billet Spindles $150
- 01 550 Trail Pipe $100
- Driveshafts $60
- 97 rmk 700 cylinders $100 each
- 97-01 rmk 600 or 700 WMS motor plate $70
- Clear tank $80
- custom lightweight seat $70
- 2 up seats and luggage racks
- Numerous Bar ends, throttles, brakes, traction plates, carbs, rails, skids, suspension parts, trailing arms, etc
425-652-9622
