M
MattZx6
New member
This bad boy is built for BIG BOOST but unfortunately I've had to get out of riding this year due to time requirements at work so this motor needs a new home.
Engine was originally out of my 06 Apex, has a total of around 1500-2000kms on it with the last 500-700ish boosted running straight race fuel.
The motor was fully built a month ago for my new project and has 0 miles on it.
This is being sold as a COMPLETE turn key setup, motor and everything necessary to make her go. Big $$ motor setup but if you want to run big boost and be fast this is what ya need!
Here is a list from the engine Builder
- Wiseco Piston Kit 10:1
- Big valve conversion
- Valve spring kit intake and exhaust
- Carrillo rods
- Rod bearings
- Gaskets/seals
- Disassembly
- Crank balancing
- Blue printing engine
- Porting/polishing
- Performance valve job
- Assembly
Motor is located in Ontario, for info please PM me...serious inquiries only
- Carrillo rods
- Rod bearings
- Gaskets/seals
- Disassembly
- Crank balancing
- Porting/polishing
- Assembly
