A
Engine 1900 miles, ARP 12mm head studs, Powderlites cam timing, .40 shim and 2 head gaskets.
Will get leak down test done when I pull engine but it will be good, motor does not use any oil. 3500.00
Expert X 136 1000.00
144 Cobra 1.325 track w/260 1.75 mega bite studs, no rips tears etc. 500.00
XP Seat Xp Gas tank and mounts Great for mid mount set up 350.00
2860RS powderlites Turbo, ported wastegate, ceramic coated, comes with oil lines and coolant lines 1000.00
Kevin Emino(need4speed) 4 tube header 400.00
Turbo Smart boost controller, single stage 12v activated 125.00
Turbo Smart Manuel Boost Controller 75.00
Stock Clutch primary with STM 60 gram base weights and various springs 350.00
Stock secondary with Ulmer Racing T helix and white spring 250.00
Turbo Fuel Pump with hoses (bosch) 75.00
Stock Injectors 200.00
Throttle bodies with stock Injectors 300.00
Van Amburg Rear bumper 100.00
Ski doo tail light with yamaha flap 50.00
Clutch jack shaft 45.00
Battery(1 season old) and tray 50.00
Delta box frame 100.00
Bulkhead and front cooler 250.00
Hand made tunnel to work with set and tail light etc. 300.00
Painless fuse box to run gauges etc. 75.00
136" Speed track 400 miles on it no rips, tears Loaded with trail carbides 350.00
Skis Shimmed and stud boy 10 inch dualies 175.00
Right side A Arms 125.00
Fox Floats with pump 400.00
Handle bars with all controls etc 150.00
Right side spindle assem 50.00
Hood with scoops 75.00 Sledneck22
Side panels 100.00 per side
Handle bar riser Rox 2" and stock 65.00
Full FJO gauges with all sensors and everything boost, temp, and A/F 650.00
2 wire harnesses 100.00 per
Stock ECU Voltage reg etc 250.00
Oil tank and hoses 75.00
Running board coolers 75.00 per
Right Forward Bulkhead 125.00
Low chrome windshield 30.00
Solid Motor Mounts New in box for apex 80.00
Front bumber 25.00
Lower plastic right side 40.00
Lower plastic left side 40.00
Nose plastic 25.00
Key switch panel 45.00
key switch 20.00
BPE gauge panel 40.00
BPE lower lauvered panel 40.00
Clutch cover 25.00
Speedo gear and pick up 25.00
Steering components 100.00
Radiator and fan 75.00
link to full listing and pictures of complete sled. Total of 1900 miles on everything
http://www.ty4stroke.com/viewtopic.php?t=86728
And everything else these are just the majors PM me with a list or email is fine as well.
aj636@mac.com
Add shipping costs to everything.
I will start taking orders now but will not commit to any sale untill the 15th.
Front bumber 25.00
Nose plastic 25.00
key switch 20.00
Clutch cover 25.00
aj636@mac.com
