Long story short my sons 2012 600 etec won't run. It starts, idles VERY slowly (as if running on a single cylinder), no gauge power, then dies after about 3-5 seconds. Occasionally, it will start up and gauge will power up and then it runs fine, with full power and everything until it's turned off.
I'm in the process of eliminating electrical and fuel problems. Can anyone tell me what this device is? It's in what I believe is the fuel return line. Fiche just call this a "hose assembly". I thought it was maybe just a return filter but I can't blow through it (at least not with it connected to the pump assembly like it is). Should I be able to blow through it? Is it some sort of back pressure regulator?
