Fuel pump
The fuel pump upgrade that comes in the 275+ kits is a factory tank pump replacement. In between the 2 vertical bronze clip looking things there is a strip that acts as the lock for the bottom casing holding the pump. It needs to be pried up gently so you can twist the whole bottom off to access the pump. You will need to grind out the hole in the bronze metal piece the factory pump sits thru as the new pump has a bigger flange on it. You'll under stand when you go to put the new pump in. It can also be a fight to get the casing twisted back on when you are re-assembling with the new pump installed.
I need to figure out how the plastic cage comes apart?
Will a walbro 255 LPh fit same as the 190. I have one in the garage from a car build I ended up selling.
