fuel pump removal
skippy
Is there anything special I need to know when removing the fuel pump. I need to get to the pump to re-install the stock FPR. Do I just spin it off? Thanks
Disconnect the two fuel lines, unplug the electrical connector, unscrew the big plastic nut and pull the pump out.
If you have a 11-12 you need the tool to remove the fuel lines. 13-14 no tool needed.
Didn't know this about the 13-14. What kind of connection do these 13+ use?
Haven't had to work on one yet!
