skippy
Need some help please...
I purchased a used 2011 Polaris PRO with a Silber turbo and Boost-it XIC on it, but ended up taking turbo off for now and put it back to stock. My question is when they originally installed the turbo or XIC do they do anything to the fuel pump or regulator that's different then stock. When I put the fuel lines back to stock I ended up taking the little external FPR that was spliced in off the sled and hooked up the original fuel in/return line to the two fittings on the top of the fuel pump and thought that was all that was needed. The sled will pop off for a second about every ten pulls but if I add a little gas down the plugs it stay running till the gas burns out. So it's definitely not getting gas for some reason. Thanks
