Fuel Pump Recall on 2009 M and Crossfires, how can we tell if it was done?
Frostbite
I have this item circled on page 30 of my September 2009 edition of Snowtech.
Owners of 2009 Crossfires and M series have been notified (I haven't been notified) of a potential issue with the tightening of the mounting nut securing the fuel pump to the gas tank.
Arctic Cat instructed their dealers to tighten these mounting nuts to 20 foot pounds, which usually amounts to tightening the nut by a half turn.
Units affected include the 2009 M series and Crossfire 500/600/800/1000 models in the VIN range of 103896 through 118441. If you have a sled in your possession that falls within this range (I do) and the nut tension has not been checked or verified, you should not use the unit until this service has been performed. Contact your local Arctic cat dealer for further details or to schedule the service.
I bought my sled last March. The sled came right out of a crate and was put together the day I purchased it. I heard nothing of this recall, my dealer doesn't seem to be too savy on this item or if it was done before I picked the sled up. I'm not getting a warm fuzzy here.
Have any of you 09 owners been notified of this recall, and had it done?
How can one tell if this recall was actually done.
Better yet, where is this nut located and I'll do it myself?
Why would Arctic Cat initiate a recall on this seemingly insignificant item (risk of fire?) and not put out a service bulletins on the Diamond Drive Bearing or the VSB steering posts bending and breaking (risk of loss of control)?
What am I missing here?
There was a lot of talk about it last season, u could try doing a search but i doubt it would give u the info u need, the search function sucks. I was also curious about this bcuz i never got any notification and i dont know if my dealer did the update. I didnt have any problems last year though so maybe i don't need to worry about it?
It is the nut under the metal plate over the sterring post. The fuel pump is in your tank and is held on with this nut on the front of the tank. It will take you 10 minutes to do this and then you can relax. No big deal I don't think.
I tightend the nut myself. you have to take off your goggle holder and the thin alluminum plate behind it that is attached to the steering support, the plate has 4 small torx bit screws that strip out real easy when re-installing. With the plate removed you can see the fuel line coming out of the tank and there is a large( i dont recall the size) nut on the fitting that needs to be tightend (becareful its plastic i think)if i remember right you might have to un plug the fuel pump wires (they go through the same fitting as the fuel line I think) you might even see some fuel leaking from the fitting, mine had a real small leak.
The recall was as stated above, simply tightening the nut on the fuel pump. Any dealer can run the vin# and make sure it has been done. Just snug it up, remember it is brass!!! If you have fuel seeping or dripping, it has not been done.
Like Eric said it was just to tighten the nut coming out of the fuel pump and YES, we did do it to yours out of the box. We checked all of them because we had one in the pre-season batch that came out of the box very loose. Let me know if you need anything else.
Alex
Now that my friends is what I call customer service!
"Like Eric said it was just to tighten the nut coming out of the fuel pump and YES, we did do it to yours out of the box. We checked all of them because we had one in the pre-season batch that came out of the box very loose. Let me know if you need anything else".
Alex
Amazing!
