Fuel pump numbers
Anyone know what the Wahlbro Number is on the m series sleds? I'm going back to a stock pump and don't want to pay $400 from cat. I know the cutler pump is a f20000286 and I can find them but I need the stock numbers. Thanks
Stock pump
You can not buy a pump anywhere but from cat they have them made for them. Your best bet is to pick up a stock pump from like me or Twisted and the reason they are so much from cat is its the complete assembly you can't just get the pump.
Ok thanks for the info. I've located a couple that have low miles on them. If I run into problems I'll get one from you. Have you had experience with the hi flo pumps cutler sells? I've heard they don't last. Would like to know what a good set up for an m6 53 series 8lbs to 10lbs of boost. Once again thanks
So are you switching the fuel pumps because of what you've "heard" or because there is an actual problem?
