Fixed---Fuel pump failing?
Just got back from 4 days riding in Alpine, WY.
Sled ran great put on just over 200 miles.
Sled now has 500 miles.
Got back home to Tahoe and went for a ride.
Sled had a problem. Would occasionally cut out, and then run and then cut out. Activated DET sensor a couple of times ( first time ever for me out of three Pros). Running ethanol resistor. 10-62 clutching at 6500 feet.
First thought ignition. Checked plugs, coil leads, caps, etc. Seemed fine.
Seemed to be getting progressively worse as the day wore on. Stab the throttle from stand still and the sled would bog, then go. TSS switch is over ridden with tape, has been since 35 miles.
Thought fuel. Heard a whining noise from fuel tank and thought maybe the tank vent was clogged. Opened cap when sled was running to see if the noise would go away when the cap and possible vacuum was removed. No rush of air when cap was removed BUT pump was making a distinctive whining sound-- sounded almost like a hamster wheel.
Thinking this is my culprit-- it would explain DET light if the engine was starving for fuel. It explains the bog. The whining sound is intermittent, as is the cut out. Thinking now the pump is not receiving 16 volts, or the signal, or the pump itself is failing. The whining sound makes me think it is the pump itself.
Anyone experienced with a Polaris fuel pump failure on a Pro or anything else that uses the same pump? Will the pump whine if it is receiving less than 16 volts?
Will swap out entire tank / pump assembly from my 2011 to see if it rectifies the situation. Isolate it to see if it the pump itself or the signal and/ or voltage to the pump.
Any input appreciated.....
