I was told by my kit builder to wire both my fuel pump and oil pump into the accessory plug, using the Cat accessory plug splitter. This is on a 2008 M1000 running a high flow in-tank fuel pump. My problem is I primed the fuel system with a 12v battery and it fired and ran for about 30-45 seconds before running out of fuel pressure. I primed the system again and hooked up my multi-meter to the fuel pump power wire coming off the acc. plug. At idle it was only showing 3.5 volts and I assume it should be putting out a full 12 volts or more. Any ideas? Does the acc. plug put out enough amps for both the fuel pump and oil pump? Do I need to wire it differently or do you think I have some other problem?
