M
mblanken881
What should I be running for fuel pressure on an 07 M8 BD RG turbo?
Also, are guys blocking the stock exhaust hole?
You ever gonna bring that thing out here & RIDE IT???????
Ask whoever you got your numbers from what psi they're matched to. IF you use one guys PSI & another guys numbers, you can run into issues.
The bottom numbers I'd guess would be pretty close, but the top should be a ways off.
Get your azz some numbers before you get out here!!!! You don't want to spend the trip tuning... and getting STOMPED ON by my little sally short track !!
blankenn heres my #'S 07 M8 BD RG turbo
5000 rpm mid -2 high-4
6700 rpm mid -2 high -4
psiL 17, 29,43
psiH 10,20,52
Cr=30
Os= 20
im at 6,000 to 8,000 feet 9.5 lbs of boost
seeing afr at 12
egt's around 1250
running 110 race fuel
try pressing right and left arrows down while you start the sled and see if your box reads supertuner mode?? if it does you should be able to scroll through the fuel menu until you get to psi L and psi H to enter #'s there and also check CR and OS #'s ??
psiL 17, 29,43
psiH 10,20,52
Cr=30
Os= 20
seeing afr at 12
egt's around 1250
I'm in supertuner mode.. But what does CR and OS stand for?
