Y
yort600
Fuel pressure problem 2005 900
If I test the pump with 12v sled not running I have the 58 psi the manual calls for but as soon as I start the sled the pressure jumps between 50 - 70 psi the needle moves so fast all I see is a black streak. So I tried another pump/tank asm. off a running sled and it does the same thing. To confirm my gauge is good tried it on my truck and Rush and it is good. Tried putting 12v to pump with sled running and still no difference. Any ideas? would a bad injector do something like that it is really the only difference there is when the sled is running or not that the injectors are getting power?
