fuel leaking
what dose it mean when fuel is leaking when the sled is sitting in the garage ?? Is the needle worn out ?? doesn't the fuel pump have a stop valve of some sort ??
also I'm looking for some good used carbs. the ones i have are pretty worn out :eek: some bored out ones would be nice :)
fuel
I've seen plenty of times where a fuel line has just worn a hole from rubbing on something. Also have seen where a fuel line gets loose where it fits onto a fitting and leaks. The newer fuel pumps rarely leak fuel into the carbs.
the fuel lines are new and fit tight and with a clamp i know thats not it :( it leaks fuel in the motor then its hard to start and the exhaust spits it out :mad: makes a mess on the garage floor :mad: i replaced the fuel pump last year but its still leaking fuel . I'm thinking it must be the floats and needle :confused: what do you guys think ??
Yep, needle seats. Repleace the seats and needles at the same time...Dennis Kirk probably has the parts or your dealer.
HA ha found it :D it wasn't the needles or the seats but the O ring that holds the needle seats and the floats in the cards :eek: it was all brittle and cracking !! but all fixed now !!
