How much fuel are your guy's sleds eating up? My BD PG/800 is very thirsty!!! I think i need to do some leaning out, because there is no way it is right.
Did you get it running good? Did you try 50 to 50 mix? Saw you posting on the other thread and wondering what you found?
Any thing over stock is going to use more fuel no way around it. The more boost the more fuel.i rode with that other guy that posted but he is alway's sitting around so do not go by what he say's.![]()
Mine ate enough to get the trail tank and still carry extra.
30% more fuel, 30% more power! If you put around and never get on it they will probably burn about the same, but who would really do that? They should burn about 30% more fuel.........but who is burning 30% more oil? Better check your oiler. If you where 40:1 before the turbo, you probably need to turn up your oil feed.
I was thinking about this on the way into work today. Maybe some of you can clear this up for me. Given that you are running the same maximum rpm, would you necessarily need to burn more oil with turbo setups? Or does the extra fuel and air warrant the additional oil usage? I've been adding a few ounces of oil per tank when filling up just for extra insurance.
Thoughts?
Thoughts?
Just check yours and see where its at. You may be about spot on now with the turbo. This is what I did. Fill oil up and top off with fuel. After your 50 mile or so ride fill up the gas and measure how much oil yours is taking and calculate it. Before the turbo mine was like 32:1, now I am running about 42:1 but I also put a little oil in the tank also. So with the oil in the tank I am running 40:1. I am hoping oil in the tank helps extend the life of the reeds also.
