Fuel box settings for pg m1000(Pure logic box)
shadow conspiracy
I tried the search function but after 21 pages i couldn't find a thing for the m1000. Only for the 800. I did use the settings from OVS. They said it would run rich and then bring it down from there. No matter what I tried i couldn't get rid of a bog. If I was at 1/4 or 1/2 throttle it would bog when i would try to open it wide open. If i feathered the throttle it would work fine. My setting are at:
Green 4
Yellow 2
Red 2
Blue/Green 5
Red/Blue 4
Fuel pressure is at 38
A/F was at:
14 at idle
12 to 13 at half throttle
11.8 to 13 at wot
Dont have much experience with the pure logic box, only the boondocker one. Seems simple enough but i just couldn't get rid of that bog and my A/F #'s where i would like them at wot. Besides that little bog the sled ran awesome.Thanks for the help. Oh this is for the aerocharger setup and i was running straight AV fuel.
I used the OVS #'s with no problems. [aero 66 pg 09 M1000] I wonder if your fuel pressure regulator is set incorrectly? I can't remember what mine is set at right now, but it might be worth looking into. Are you making any boost? If so, how much? I did have the clip come off of the retainer for the boost/vein actuator which wouldn't allow it to make any boost at all. It's an easy fix. Just a few easy checks, hope they help.
ya it makes boost(5-6lbs) It won't make boost with the bog until i feather the throttle.
Smoothdawg, what were the settings you got? I was just told to use the settings they have on the website which are for the Garrett setup and that they would be rich and tune from there. Also what kind of track speed do you see?
if your red blue is the rpm to add the fuel in your red setting... it is to low...should be around seven...imo..that could be causing your bog because you aint quite spooled up and your getting that burst of fuel..
well i aint got a turbo..but i have the purelogic..and i assume the red blue is the same...and its to low...and if i remember correctly reading other posts with purelogic and altitude boxes on turbos they are generally at 7..and mine is at seven for my n/a..
