FS RK Tek M8 head
Dam Dave
FS RK Tek M8 head SOLD
SOLD
Used RK Tek M8 head, 14.5 domes, 7-9 th ft, I used it down to 6000 ft but took it easy till I got higher, used 2 years on my M8, bought a 2010 M8 so don't need it anymore.
200.00 + 10.00 shipping in the US only, paypal preferred, ready to ship today
Our new "QUAD"Head is nothing short of AMAZING! This head will completely change the way your engine performs! There is NO other "bolt on" item you can add that will provide the gains this head will!!
The ENTIRE power-band is widened and the throttle response is increased drastically! Top end speed is increased!
This head will be featured on Chris Burandt's and Chris Brown's "TRICK" sleds. This head is a "MUST" for any person wanting to get the most from their CAT TWIN!
THIS IS THE REAL DEAL!!
Our Billet Head will add the NEEDED cooling and increase the power, as well....
The power will come on sooner and allow for more over-rev. This will come in real handy when adding pipes!!!
RK Tek has also spent much time developing a SOLID porting package to compliment the head
At RK Tek, we tend to look on porting a bit different than most other porting houses. We REFUSE to alter ANY engine, via porting or other modifications, to a state that makes the engine "PEAKY" or have an explosive power hit.
We have discovered a special type of porting alteration that allows for a very smooth power delivery and NO sacrifice of low end power and especially no sacrifice of engine reliability. On the ALL the Laydown Twins, we found the port arrangement lacking to say the least.
We have uncovered some serious hidden power via porting alterations. These engines are a completely different power-plant after the porting and will surprise many larger bore engines on the hills or on the lake.
Could you run this head below 6000' with a boondocker controller and be safe? I would be adding it to my speedwerx setup if I bought it. I ride mostly around 7-9500, but I occasionally ride in the black hills from 5000-6500.
Thanks
