E
endeavorslc
New member
The High Performance MPI Nytro Exhaust System saves weight but increases dB levels. The new exhaust system weighs just 4.75 pounds, with the OEM system weighing over 17 pounds. It was designed for use on Stock and Supercharged units. As this system has significantly less backpressure than the OEM system, Turbo should consult their kit manufacturers, as the increased flow and reduced backpressure will likely be detrimental to a turbo's performance. The system is made of 100% stainless steel and exits through the stock cowling behind the seat. The unit includes a billet aluminum tip.
FEATURES:
- 100% 304 Stainless Steel Construction (including brackets & internals)
- Complete Unit Weighs less than 5 pounds
- Billet Aluminum Tip
- Mathematically designed "Quiet Core" inside the Muffler to reduce noise, not flow.
- 100% TIG Welded
- Increased Exhaust Flow
- PLEASE NOTE: This unit is louder than OEM, but not ear piercing.
Click for Larger Image
Click here for Larger Image
MPI Nytro Lightweight Exhaust US Dollars
eaa-3500 Nytro Stainless Exhaust System (saves 11lbs & is 100% Stainless) Intro Price $ 319.00 from MPI
FS at $200 plus shipping
FEATURES:
- 100% TIG Welded
