front shock adjustment?
Ryanlilly
Polaris
I put a set of zero pros on my edge and it seems to push a lot more in the corners. I also put a M10 skid under it and went from a 144 to a 162.
Do I not have enough spring pressure on the front shocks? Or am I way off base?
The 162 is bound to push more than your short track no matter what you do. You are on the right path though with your thinking. I would 1st try back the front, track spring off as light as you can get away with running it without bottoming out. This will help its ability in the powder as well. Then, crank up the ski shocks as needed from there.
