In the process of changing the oil in my front forks.As it turns out,you have to tare them right down to clean them properly.Manual is not the best at explaining the process but with a little help from others ,fiqured it out.
Unless I am missing something ,I need a tool to reinstall the bottom bolt(shim pack) through the bottom of the tube and into the cartridge to hold the cartridge in. I was able to brek it loose with the impact but could not tighten it.
So far the only thing I have come up with is a piece of square tube to slip over the 4 flats on the end of the cartridge or a 12 point socket welded on a tube because it has to go 10" down the fork tube
Any idea how much these tools are or do you have a pic of one
.I will try it tomorrow.
Here is a pic of the cartridge
