Front End Question
Hey guys, I need some help with my edge. Took it out 2 weekends ago and the thing almost killed me when I tried to carve on it! Is there a way to make it alittle easier for me? I know about the sway-bar removal and all but what about a narrow front end kit(does anybody even make one?) and new shocks, would this help out at all? I want the front end to be higher also. Thanks in advance.
Remove the sway bar, and narrow up the radius rods at the trailing arms. If you have already done that try lowering the spring pressure on the front shocks and letting out the limiter straps on the skid.
I Wanted it to be more preditable in a carve so i put in some spring spacers from polaris. Helped alot. They are designed for the sportsman atv's. I have found the stiffer the front end the more predictable it is so i have it almost as stiff as i can. Got the limiter strap all the way out and helps a bunch and narrow up the ski stance and for an even narrower frontend pull the radius rods and cut them down. i would not cut more than a half inch off each side of the rod tho. It will narrow the ski stance another 2 inches total, every little bit helps
