Front end alignment
long 9/16" open end wrench. But first you loosen up all four engine mount bolts and lift the engine up several inches. You also adjust the rear and not the front. But there is no reason to even touch this steering tie rod (unless it is loose) because ski alignment is set by the tie rods that attach to the steering arm and/or by readjusting the steering arm on the spindle shaft.
Well the reason for adjusting it is cause I put a new tie rod on the right side and my handlebars are crooked they are cocked to the right so I figured I would have to adjust the left side right
