Anyone else haveing troubles freezing off there air pod on an MCXpress turboed Nytro in Fresh powder? Was thinking of wrapping the rear shield between the center divider & left hand plastic shroud with nylon material that can be just knocked off. Did this years ago on the windshield to cowl of a Viper with cold air kit,Worked fine but that was up high not in the snow dust from the track. Any suggestions or ideas? Someone else must have had this problem. Would also like to modify Exhaust like Darko has suggested.I think the heat from the Exhaust helps to freeze off the air inlet,because that side of the sled sure collects snow & Ice.
