Free DIY Mods
ScubaSteveSK
The only thing better than doing a mod yourself is a free one.
Last night I cut down my stock windshield and straightened the lugs on my attack 20. What are some other free projects you've done on your sleds?
i couldn't afford a boss seat so i used the foam from a torn seat and made my own highrise.
Not really mods but I have to do something to the sleds while on strike...:rolleyes:
I removed most of the decalls from the side panels on the REV and installed a 2 stage throttle on it to relieve most of the trigger tension.
No more cramped hand at the end of a long day.
Now I need to make a plate out of some thin stainless or even aluminum to re-mount my Snobunje lefty (I know what you're thinking but I actually use mine and like it!) because there is very little room on the bottom of the new trigger.
Next I'll be going through the clutches and chaincases and lube the chassis.
I thought about drilling the track but I'm just not sold on it yet.
All free...For the most part.:D
Grab the holesaw and port everything! Track, hood, snowflap, windsheild and don't forget the chaincase, rotor and driveshaft. I guess the Doo guys don't have to worry about the driveshaft, I hear they are "self porting". :face-icon-small-win
Venting!
:D
get the hole saw and put a hole in anything you can rip it thru, and sawzall
i dropped like 3o pounds using just these two tools, but the sled looked kinda messed up after it.
Is that silicone under the kill switch? presumably for a press to kill kind of action?
No, it's actually one of those stretchy hair thingys that my wife ties all her hair up with. It's just wrapped around 2 or 3 times.
I put it on there about 2 years ago while on the hill to solve a little issue I kept having that day!
I have to hold the kill switch down now to kill the motor because the switch springs right back up when you let go.
No more accidental cut-outs in a climb!:rolleyes:
The thing I did to stop my accidental shut downs was to swap the two wires in the plug on the handlebar. So now when it is down it is on and to kill it, I have to pull it up. The thing works great this way.
WOuldn't that make it a little harder to kill in a "falling off the sled" kind of emergency?
Probably no more than a womans hair band under it though.:D
Porting the track is a good one.
Ripping all the insualtion off under the hood.
Relocating the handelbar controls.
Setting the suspension up for you personally.
Will be....
removing the hood foam and replaced it with heat tape.
removing the headlight and added off-road lights
porting (thats a funny word) the belt cover plate
hacking off the sway bars
removing the gas rack and tail light. Will be replacing with an LED light bar.
removing the hood screens and replaced with pet screen
Already did..
removed the front idlers
cut down the windshield.
Most of it is free... but, everything that I need to get will add up to about $45-50 if that. (lights will cost the most)
Rotax what did you use for adheisive on your screening? Thinking of drilling some holes myself.
Household Goop, get it at walmart in the caulk/silcone/adhesive area next to paint. :D
Have done multiple hoods/panels...over the last 5+ years.
Works great...messy, but works.
I lay down the goop around edges, then lay the precut mesh/screen over it and pull it tight and press the goop through the mesh/screen at the edges.
Did the "Geo Mod" on my 08 M-sled. Totally free and love the results!!!!
Will be porting the track, two wheel conversion and adding side panel vents...total cost...approx. 50.00:face-icon-small-win
