Just wanted to say a quick thanks to all who post such useful info on the 9. I read many of the stickys and used a ton of info off this forum.
Long story short: I'm a new '06 9 owner and didn't check out the sled as good as I should have. Shouldn't have let the low mileage and outward appearance fool me! Upon closer inspection at home found badly scratched up pistons (water in fuel or snow ingestion?) and low (115) compression so I tore it down. FIRST SLED OVERHAUL!! Had a couple "What did I get into???!!" moments and turned to the forum for help. Also found a cracked jug. Got all the parts gathered and had a local shop assemble the top end.
Engine install went went fairly smooth with all your help from engine mts to throttle cables to bleeding fuel, A/F and oil lines and much more. Started 3rd pull...have taken it on a couple short break in runs.....seems to be perfect so far but haven't gone WOT yet. Hopefully this one last longer than the original.
Installed the full Frogzskin line of vents last night.
Thanks for the help with my Frank'nstyn 9!
