Fractures??
A
anziconda
I have heard this term many times in reading about avalanches...just wondering if anybody has more info about this or pictures..I'm sure its hard to get a photo of them before a slide, but they would help a lot of people if someone gets a chance. Also just tell me what is meant and what to look for. I have ridden Montana the whole time I've ridden and never seen any "fractures" that were obvious...Maybe I just don't know what to look for, but if I saw a definate fracture in a virgin surface, common sense would steer me away from that slope. Thanks
Fracture Lines
It is my understanding that a fracture is the line you see when two layers of snow begin to separate. The bottom layer is called the bed layer. The bed layer can be the ground, a hard crust of snow, or just generally a layer with different density than the one above it. I have seen a few and have definitely stayed away from these slopes. They are an excellent indicator of a potential avalanche, although not all slides are precluded by this fracture line. My 2 cents. I will try to remember to take a picture the next time I see one. Doug Chabot from the Gallatin National Forest Avalanche Center probably would be able to email you some as well.
If you have been reading about avalanches you have no doubt seen the terms 'weak layer', 'bed surface', and 'slab'. Fracture or fracture line is just refering to the spot where this 'slab' breaks off and starts sliding down the hill. The slab slides on the bed surface, and the tiny layer of snow btwn the slab and bed surface is the weak layer. So the portion of the slab above the fracture line stays in place while the portion of the slab below the fracture line tumbles down the hill wrecking all things in its path. You will also read about 'shooting cracks'. These are basically the beginnings of a fracture line and a very big warning signal to get the hell out of there, they can run anywhere from a few feet to 20-30 feet, any longer and they will probably completely fracture and the avalanche begins. This is what you need to be aware of and avoid, as its telling you there is a lot of unstable energy in the snowpack. There is no doubt in your mind when you see a shooting crack, it's very obvious what it is and the hair on your neck will stand straight up. However on a snowmobile you can easily miss these signals since we tend to move pretty fast and make lots of noise that masks any signals the snowpack is giving us. As a skier you have a much greater opportunity to see all of this stuff. Your best opportunity to see a shooting crack or even a full fracture without being in danger is to find a pocket of snow that has been windloaded, this snow will tend to be more cohesive and layered making it easier to see some cracks if you ride through it or walk around on it. Be sure to do this only in a safe area, 25 degree slope or less and not attached to steeper areas. Or better is to find a small windloaded test slope that you can cause to avalanche safely. Trust me, if the snow fractures you will recognize it immediately, the problem is it may already be too late at that point. Hope this helps.
