Fox zero x shocks on front of Pro RMK
mt.sledder
Where is the best place to mount the remote reservoirs on the front of a Pro-Rmk? Can it be done???
Under the hood... mounted to the overstructure tubes...IMO.
What length, spring rate and valving do you have in the Zero-X's? (what were they made for originally?)
You may be bolting on a shock that does not work as well as the stock shocks.
My 2 cents.
Shocks are off a cat snocross sled, the bodys are the same length but the shafts are a bit longer. As is they won't compress as short so may have to get shorter shafts installed. They have adjustable compression and rebound.
Those are great shocks...Worth putting some money into and setting them up right for your sled... that would include springs, valving and length.
Good luck.
