fox zero pros upside down or not
I
iq high marker
I didnt no which forum to ask this question but i ride a 08 700 dragon so im here. I just took off my walker evans floats and replaced them with fox zero pro shocks there brand new and valved pretty stiff but i dont know if I should put them on upside down or right side up the guy that built them said either way is fine it doesnt matter but when i went to my local polaris dealer and was talking he says bull$H1t he has to valve them the way there going to be mounted it would be great if anybody had some input thanks alot for any help by the way i mounted them upside down for now but havent rode it. I also read and add in sno goer about putting shock either way and they said nothing about valving. Thanks again sorry it got long.:face-icon-small-sho
Either way will work. I mounted mine right side up, but had to grind a little on the mounting bracket to do it. I was told by fox they can be installed either way, works the same.
Oops, didn't notice you were talking about Zero Pros. Mine are the fox float 2. Sorry, no experience with those. You might call Fox, I asked them the same question about the floats.
Carls cycle suggest upside down! Supposed to kinda block the shaft from getting knicks and scratches in them. But it is harder to check air pressure this way!
