I am disassembling for rebuild a rear track shock for a 1.5 zero pro remote reservoir. I would like to remove the adjuster assembly to replace the O-rings. I have removed the screw holding the valves on the outside of it and applied pressure to try compress to gain access to the snap ring but it is not moving inward. See attached "adjuster 1" image, this assembly needs to move inward to be able to provide clearance to remove the snap ring. Also does anyone have the IFP dimensions for the zero pro shocks installed in a 2003 edge RMK?
