is there a fox float and a fox float 2. if so can someone tell me what is the difference?? thanks
i have been recently schooled on this, by jodi at carver performance. "SOME" original floats can be converted to float 2's.
the stock arctic cat floats do not have a negative spring in them (cost savings), where the fox floats (off the shelf) do. you cannot add the negative spring without reducing the overall travel of the shock. so literally you cannot upgrade the stock cat floats to true float 2's. you can upgrade the valving and air bearing but, it still is lacking the negative spring.
if the orginal float has a negative internal return spring, you can upgrade to the float 2 specs. ski
Wow the Evol X is 4.6 pounds and the standard Floats are 2.1 pounds. Interesting.
