Rider weight with gear(pack): about 235-240lbs.
Rear shock air pressure: 110-115 psi.
Altititude will not affect your shock pressure as it's a compressed gas (O2) with in the shock itself.
Temp. on the other hand may affect your psi readings from day to day or as temp. changes, but it would need to be a significant change in temp.
Reese
we have a tire shop fill some of a rigs with N2 it stays more constant over temp and alt so no air in the spring just N2 should do the same thing right?
I was going to start with 135 of N2 and if i had to let some out fine and if your on the hill and have to add 5 lbs of air no big deal.
Well, air is 80% nitrogen anyway, so pure n2 is only a 20% improvement...?
Exactly... I work at a car shop and just laugh at the people that get pissed when you adjust their tire pressure and they say, "wait did you use nitrogen?? You shouldn't have used air because they shouldn't be mixed" it's always funny when you tell them they've wasted money because "air" IS 70-80% N2 anyways.
LOL
I watched my buddie do that once and without even thinking he looked at the guy and said " we only put N2 in all our tires, but we don't charge for it like everyone else " his boss had to leave the room to bust a gut.
