C
CarverPerformance
New member
This kit will add extra air volume to the Fox FLOAT ski shocks. Kit includes a set of two EAV's and hardware for mounting to shock.
We have found through extensive testing that the Fox FLOAT shock does not provide enough air volume in it's standard configuration. As the shock compresses through it's travel, the air pressure builds and becomes very harsh at full compression.
These chambers allow higher initial pressures to be run but still allows the shock to use it's full travel without becoming to stiff.
These kits are very easy to install and do not require you to remove the shock from the snowmobile.
Price $299.95
Price $299.95
