fox float evo setup
hi there,
just installed some fox float evos on my xp.....seems no matter how i set em up they feel to stiff.....any ideas or advice.....i like my setup pretty plush...i like to do downhill carves but also like to do drops and lots of jumping...i way in at 165 or so....
thnx in advance
jason b.....
i have a perfect plan you send me your shocks and ill send you mine they are diffanitly softer..... haha how much air you running in them? drop another 10 pounds considering your a light weight
no matter what you do for shocks you get them set up for one thing or the other. carving or jumping. you can have them set up for the middle road as a compromise. but either way spending 1200 bucks on shocks with reservoirs is typically not the answer for mountain riding. they are oil storage tanks for riding down bumps that overheat your oil and cause fade. they do nothing for jumping or mountain riding for that matter. the air shock aspect of the shock is kinda neat though. you can adjust it for the riding you plan to do. soft for powder days or stiff for booter days. the down side is you have to figure out that appropriate pressure for you and that day and keep it memorized to cut down on tinker time. all you really needed was the regular floats. the evols look sweet but really dont do much for mountain sleds that arent hill crossers sell them to a short track flat land ramp tramp. and get the regular floats and save the rest for the money for a new set of pistons and rings so you dont have to spend too many days down when your engine says i quit for now. a handy spare top end is just that, handy. my sled is really long so i just run fox zeros for mountain play. i jump a bit and feel that if i go any bigger ill bend my sled. this summer im gonna get a shorty so i can really boot with my buddy wes.
I love my EVOL's best shocks I have run bar none.. Compared to 440 shocks, Z-bros etc. the nice thing about them is you can set the main chamber up softer for carving if that is what you want and the EVOL chamber up to prevent bottoming. They take some dialing in like anything but work great!
Both my chambers are set up very stiff I also run the sno cross valving in my Mtn sled and use a modified 151 skid in the rear.
Give Holz racing a call (360-398-7006). Mark has got the valving and pressures dialed in for the XP. I have HRP front and rear suspension on my XP which also has evols and its perfect. My buddy and I rode up a whooped out road together (he has a newer cat) and I could ride at least four times faster than he could. We switched sleds and he said hands down the best suspension sled he has ever ridden. As far as carving down hills I have no problems cutting the front in and even turning the sled around and heading back up hill. You also don't need the sway bar on the front anymore with the Evols.
T
Set the compression damping (high and low speed - if your shocks have both) and rebound damping at the lowest settings, main chamber 50 to 70 lbs., and the evol chamber around 150 lbs. This will give a fairly soft ride. If it bottoms too easy, increase the high speed compression damping and/or the evol chamber air pressure
