New in box $550
The most progressive, adjustable, lightweight air shock on the market
All adjustments can be made externally using a hand air pump; no tools required
Fully adjustable air chamber gives a progressive spring rate and provides significant weight savings
High internal air volume for increased air pressure for better roll resistance in corners
Precision-manufactured damping pistons for maximum consistency and flow characteristics
Race-proven velocity-sensitive damping control technology
Aerospace-grade PTFE-lined spherical bearings to maximize durability
Anodized Internal Floating Piston (IFP) and bearing housing to prevent oil contamination and boost seal durability and lifespan
6061 T-6 aluminum piggyback body caps, shock bodies, air sleeves and reservoirs
New, easy-to-access Schrader air cap for main air chamber pressure adjustment
Piston valve stack can be adjusted
Shocks are serviceable and 100% rebuildable
Genuine Kashima Coat with distinctive gold color provides smooth performance
Samurai sealing system is a highly durable material that scrapes away snow, ice and debris while keeping seals lubricated for minimal friction
Measure 17.1" L and weigh just 2.1 lbs. each
