G
GtownRidah
Been searching through some threads and found very few setup psi and rebound settings. I was hoping people that run the new Float 3 versions, fronts/rears or both could post up their usually setups. If you want toss in your ride weight, typical riding terrain, jumping, etc. Also, how often do you change them for different riding conditions? Do you run a swaybar?
I just installed them and have no rides yet. I understand I will need to adjust them but I figured getting a bunch of numbers in one thread could help others.
Started with (at 25F degrees): Burandt Edition shocks
Fronts: 65psi main, 125psi Evol, rebound 10 from soft
FTS: 51psi
RTS: 150psi main, 175psi Evol, rbound 15 from soft
FTS: 51psi
