Fox Float 3 Evol Front Ski Shocks
VittMaxx
Center to center extended length is 17.15" and collapsed is 11.91" for a travel of 5.24". Like new. 200 miles on them. Asking $580 including shipment.
The new Fox Float 3 shocks now feature a high-performance Kashima Coat
The distinctive gold color is backed by its high-performance properties that provide an exceptionally smooth feel and extreme durability
Kashima Coat offers superior durability and hardness, and reduced friction
New, easy access air valve location
Samurai Sealing System (SSS)
EVOL Air Technology
Aerospace-grade PTFE-lined spherical bearings
High-flow velocity-sensitive damping
Chrome silicone negative spring
Fully rebuildable and revalveable
Ultra-lightweight
EVOL and main air chambers can be adjusted independently
Fine tune ride height and plushness with the main air chamber and bottom out resistance and roll stiffness with the Evol air chamber
Adjustable main air chamber and Evol air chamber
This includes two Float 3 Evol Shocks (one left side & one right side), 300 psi air pump
Shocks
Any idea if these will work with a timbersled front end for a yamaha rx 1. I will start resarching myself , but just incase you know , pls share.
Beau
What did these shocks come off of? Need this info to know what the valving would be and if they would need re-valving to work on my Proclimb. Where are the shocks located?
