Rear Shock Setup
Worked with Russ at Hygear Suspension. Revalved Rear Shock, negative spring, 2 Chamber Air Canister similar to Evol Chamber, and I had them install a compression adjustable resevoir. Works great through the stutters and big drops. Launchs flat off of jumps without the kick the stock suspension gives. Easy to setup and adjust when I am packing a 2 1/2 or 5 of gas on the back. Run Evol Rs up front love'em.
