This was my PM's from HCS.
Hey I just bought a htg 975 and had a few questions. I got the updated porting and pipe. This engine is brand new and not even assembled. I also have a htg programmed ecu. Are you running yours with a bd box and stock ecu or is yours htg programmed too? What clutching are you running- does rob have a kit? I also got another boondocker nitrous kit with this, ,with a custom programmed BD box that has more RPM ranges on it. Do you run a map just for pump gas or just the nitrous? and lastly what numbers are you running and what fuel you running for nitrous?
Thanks,
Scott
my 975 i was running a htg program box, no issues with the fuel curve, the one thing, i dynoed at dynotech on the dyno the motor made best power at 7400-7500, even though rob told me to spin it at 7700-7800, at the lower rpm it pulled like a train, the clutching i was using was 78g hammerheads, from speedwerx blk/green pri spring pol. 58/44 full progessive helix red/blk sec. spring, i also had 50 shot boondocker, my fuel # was 35, but i would start at 40 then work your way down till it runs clean, i never had any issue with the motor with about 30 bottles run through the motor, when playing with the no2 i ran 110, trail riding i always ran 93 . the motor sits on my bench now as i am running a 1140 now with the juice, oh one other thing, on the juice i swithed the helix to the 58/46 angle and then hold on!!!!!! but it couldnt pull it when trail riding
