forward post
No Is Does not
To install the forward mounted post you need to remove the belly pan, airbox, and carbs, you will also have to noch out part of the motor mount and frame work for the oil tank, because the bend in the post will hit these things, check out the pictures, also the post will have to come out the bottom, one of the best mods you can do to the 1m series sleds MADDOGWFO, I am also running a 3 inch riser on the post
No Is Does not
Do not worry about modding the stock airbox the post will clear and with the bend in it, it will clear the carbs just notch out the places I mentioned before MADDOGWFO Ps forgot to mention you have to mod the hood to clear the post
