Sounds like a lot of v10 fans on here, I had a 2000 v10 in an excursion. That Excursion was the nicest rig I have ever owned and I currently drive a 2008 3500 LTZ Chevy crew cab. It only had a few drawbacks like ball joints, exhaust manifold studs, spark plug getting stripped out, differential seal leaking, automatic locks failing. At 80,000 miles I took it to the dealer to have the plugs changed (even though the manual said 100,000) The bill for changing the plugs and coil boots was over 900.00 alone! Then they wanted to tack on almost another 300.00 for repairing the plug they stripped out! They didn't even try to fix the broken exhaust manifold bolt. It was 90,000 miles and the front end was shot, ball joints on both sides, tie rod ends and I had one hub that kept sticking so new hubs as well. Not to mention the girth of these trucks gives them no advantage. They don't drive well, handle like a 26' straight truck and have a poor turning radius. I replaced it with a Chevy 5.3 crew cab 1500 which did "ok" and I turned around 2 years later and got the 3500 Chevy crew long box single wheel with a 6.0L gas that does a real nice job. I'm not bashing and I can't say if any other brand in this era were much better. All I can say is I thought my previous Fords and Chevys were better vehicles to me.
