Ford Door Ajar Sensor---
J
JohnnyQuestUtah
Door Ajar Sensor for driver door....Where is it?? Have a 01 Ford, and the sensor is out of control,the Dope light and dash alarm is going on and off in rapid fire !! a bit like a strobe light on the way too work tismorning..........
Peace-
I had mine malfunction this summer... it is annoying for sure.... you can slam the door as hard as you want and it still thinks it's open:face-icon-small-dis
Best cure, shoot some WD-40 in the door latch, the sensor is built into it and gets sticky over time due to dust.... I did this and have not had a problem since (6 months).
:beer;
Lube Job
Same as 94guy, I have a 02 Excursion, had the same problem with the drivers door and the rear door, sprayed some Red Grease in all the latches & the lights stay off. Wife has a 02 Lightning had the same problem, lubed the latches & presto - all is good.
