jfox1995,
The 6.4 is a good motor with plenty of power but less than good fuel economy. The fuel economy issues can be delt with by doing a dpf delete (programmer, exhaust and intake) and with the DPF delete the 6.4 can make incredable HP but at the cost of your factory warrenty. The biggest draw back to these trucks with the 6.4 is when you have to work on the motor they require taking the cab off to work on the motor, change injectors etc. and thats not cheap. I believe the 6.0 is the same.
The biggest complaint I had with this truck (6.4) was the poor fuel economy caused mostly by the exhaust filter and the almost constaint (every 500 miles or less) exhaust filter cleaning mode.
As far as the cummins 6.7 is concerend I just traded my 6.4 ford in for one and out of the gate I am getting 16.5 mpg where the 6.4 was getting 13.5 mpg on the same trip. I haven't yet towed with it yet, just got it last Saturday. The 6.4 got 7-9 mpg towing with a 3.55 axle ratio.
I will say that I believe the 6.4 has quicker off the line acceleration than the 6.7 cummins; twin turbo v-8 vs, single turbo i-6 but it's like comparing apples to oranges.
The new 6.7L ford diesel is supposed to be an incredible motor with great fuel economy and power. For me, I wanted to go back to what I know and have grown to love... The cummins diesel motor. Yes, the new Fords and GM's have the current edge on HP and torgue but at what point do you personally have enough. With my old 5.9 HO with 305 HP and 560 ft/lb I never found my self saying I really need another 95HP and 200 ft/lbs to make this truck truely do what I need it to do.
My experiance with cummins is the fuel economy improves over time as the engine breakes-in. When I first got my 03 5.9 cimmins HO it got 16-17 mpg but after around 50-60K miles that improved to 19-20 mpg. The highest MPG i got with the 5.9 was 23.5, empty on stock sized tires. Towing 7,000 to 10,000 lb it has averaged 12-13 mpg with 3.73 axle ratio. 03 5.9L cummins 191,000 miles and still going strong.
It is my opinion that all three light duty diesel truck mfg make very good 3/4 and 1 ton trucks all with (+/-) and to me it all boils down to personal preference. None of them are designed for short trip daily driving and that is the duty that you see people having the bulk of the mechanical issues.
