For us big boys, where do we set the suspension?
snow4me
New member
Until the fat guy springs are available that is. Going on my first ride this weekend and I don't want to wreck a shock. Just looking for a general setup. Thanks.
Manual has adjustment info. Picked up heavy spring (7043740) for pro rear spring 12-31-10 works great. Found that stock spring would bottom easy and sled would wheelie to easy while climbing even after adjusting in more preload.
Didn't know that spring was available, good to know. Did you have to pull the skid to swap it?
Put it on it's side removed bolts for rear arm only. pull bolts from the shock remove spring. Did not even loosen the track, just locked brake and used a bar through track window to align bolt holes when you re-install. While you got in side good time to grease suspension. New suspension sure is easy to work on.
