? for someone with speed werx on m1000
need some boondooker # for m1000.
my mods are
speedwerx y pipe pipe and can
b.d exhaust valves
v-force reeds
and i ride around 6000'
right now got it running 800 on the egts at mid range and 1200 at high range it does not run as crisp as stock at low and mid range.
i might get rid of the pipe and vavles if i can't clean it up.
anyone with this setup out there or should i just get rid of the valves ?
Just start bringing your numbers down on your box in the bottom and mid. Im running minus numbers from idle right up to 6700 rpm then pour the fuel on after that. You have egt gauge to keep an eye on it so I would not be worried about leaning it out.
