There are a ton of threads on the foam removal. People take them out because they just soak up water and are really only there for sound insulation for sound standards. Just make sure you get some heat insulation tape so you don't melt plastic. The stock can will rub up against the plastic.
I did the same thing Bigrock, I was also thinking about the hood, but I dont know if its close enough to worry about it?? I used duct tape to get the old stuff off worked very good! Here is that other thread you were looking for alsohttp://www.snowestonline.com/forum/showthread.php?t=274828
